cut that cable!
Jamoco, do u use that for 'ehs', or just common grade. We use EHS and the box store cheapie bolt cutters are really harshing my mellow. In the sherrill catalog that felco has a subscript next to the picture that reads 'not for EHS'...just wondering if that is accurate or if the manufacture was just underpromising for some reason. Thoughts?
Sincere thanks,
Matt.
Also, we use the rig guy's, they require a clean cut. Does the grinder leave a nice clean cut?
It depends on the cut-off wheel that's used.
The distributor of Pferd cut-off wheels is in Plymouth. I'll find their contact info. Pferd have always been my favorite.
Sorry to hear bout your use of Rigguy cabling hardware Matt.
And yes I cut up to 7/16th EHS cable with my Felco cutters.
But I've no doubt there are better more expensive cutters out there, like the Greenlee, though I've not used them yet.
Rigguy hardware sucks in my opinion, and there are threads here I believe on why that go into detail.
Essentially it boils down to no wire cable MFR approving RIgguy fittings for use with their cables due to the unwrapping and separation of cable strands, then crushing each strand, compromising the galvinized coating, then hiding all this damage away somewhere it can't be inspected.
Good luck with your cabling Matt.
jomoco
Personally I'm a big fan of manual ratcheting cable cutters. Easy operation in the tree, with no need to brace yourself, and they cut the cable by compressing from all sides, so that the cut end stays together and threads easily if you're using end pieces into which the cable must be threaded. They're a real game-changer in terms of ease of use. I bought a set made by Baudat in Germany. They're not cheap, but they're worth every penny.
