Bridging dunnage is like leaving your dog in the car during the summer. Some people roll the windows up and leave for a couple hours on a 100 degree day, and have a black car. Some leave the windows down and come back in 5 minutes and have a white car, and when it's 100 they leave the dog at home. A little common sense goes a long way, and the blanket statement "no bridging" ignores that. Tell it to the house movers, you see the way they crib out entire homes? And they work UNDER the house! Obviously they do it right, if someone is breaking dunnage they are doing it wrong, again obviously.
I went back in this thread and looked again at the first picture of the crane's outrigger dunnage, and have to back up a bit and also chime in: that's a pretty good sized gap! And a good sized crane. 50 ton? My first thought was that he must have run out of blocks, then I saw the nearby pile, so not much excuse in this instance. My idea of leaving gaps, if any, is much less, 2 or 3 " and clearly not enough to worry about. But the times when I need to shore up very high, leaving that slight gap may make the difference in having enough to dunnage to get level before running out of outrigger travel. I was checking out the local fire departments 100' ladder truck a while back, and noticed that had similar out and down outriggers, but in addition they had a big pin they could pull so the pad would drop down (it was telescoped inside), then they put the pin back in (several holes) and THEN they hydraulically pushed it down. End result more over all travel so less dunnage needed when setting up on a slope. They didn't carry any, that didn't seem right.....
