- Chardon, OH
Battery Replacement Blower for Sthil Gas BR-600 Leaf Blower ?
My Sthil BR-600 has been excellent; for several years; easy start & reliable.
677 CFM at 238 MPH & 64.8cc engine.
I use it primarily for fall leaves, excessive grass clippings, & small stick clean-up, etc.
I think you need VELOCITY to pick up material (especially if wet), then you need VOLUME to move the material.
It has started getting hard to start. It will run if I play w/ the choke & get it thoroughly warmed up.
Unfortunately, my local mechanic has quit working on all 2-cyl equipment. (too finicky ?)
His short recommendation: Buy a high-performance battery leaf blower. “You will never have a problem ! ! !”
What are battery powered, back-pack blowers, w/ similar or better specs, & at least 1 hour at full power?
