The feed wheels were initially not spinning but I got it something must’ve hit the safety cords. Now I’m wondering how you adjust the auto feed.So are the feed wheels not spinning (title problem) or is the auto reverse pushing the brush to far out (post body problem)? Two completely different problems, one can be a simple computer adjustment the other not so much.
Perfect on problem solved. Which tach do you have? If it’s the same as mine (I have to look to see which I have) I’ll take a picture of the operator manual pages that pertain to auto feed and auto reverse adjustment. I need to it up anyhow as I’m having the same problem half the time when chipping wood.
Thanks a lot. So will the temp settings change the autofeed pushing the brush out to far?Great you have the same intelli-feed system.... but all the manual offers is temp setting changes (see pictures). For technical assistance though you can call (815) 985-0383 or email larry@indelecon.com.
I don’t understand why we can only make temporary changes to this. I watched the dealer mess with it when we demoed our machine I was assuming he was making sure the adjustments were correct but obviously they reset one the machine was shut down!
View attachment 50527 View attachment 50528 View attachment 50529
Yes read the directions completely because it all starts and the beginning. Reverse time is the last in the adjustment cycle. Bottom of page 14Thanks a lot. So will the temp settings change the autofeed pushing the brush out to far?
Awesome. Thanks a lot for your helpYes read the directions completely because it all starts and the beginning. Reverse time is the last in the adjustment cycle. Bottom of page 14
