- Northern California
Re: Are you considering a lowering and lifting dev
I mean know disrespect to any of the folks who provide the GRCS lowering and lifting device for the general public to purchase and use in the field.
I will however provide the end users a small piece of advice so you don't, maybe, get killed on the job.
If you are using the attachment that is intended to lift objects with, be cautioned that it can and has exploded during the operations of lowering.
If you intend to lower extremely heavy objects, which the heads of the device to the fixed drum.(of course not during the lowering process)
I mention this concern to all users of the GRCS device so that at least you will be alert and can caution everybody you instruct.
The GRCS is a wonderful device when used and installed correctly and managed properly.
The attachment will show you what happens when you don't heed caution and excercise discretion when lowering heavy objects.
Again in closing, I did not mean any ill harm with this information, just a reminder to read the instruction manual and listen to the advise of exprienced users.
