Brian, Brian, Brian,
That old tautline hitch climber mentality is creeping back out of the depths of your psyche
Keep him in control.
Thinking of the practicality of the RG, you're right, its an expensive, over $150, replacement for a free branch union in the same way that a ratcheting lowering device is an expensive replacement for free tree wraps. This is another example of the arc in the curve of arbo technology.
This is the way that I explain the natural crotch to RG spread.
Consider a natural crotch as a zero. This takes everything into consideration and is the low end of a baseline. Cheap, always available, lots of friction, hard on rope, hard on tree sometimes, tree wrapping rope leads to more friction, etc Now, as we go along, you know all of the pluses and minuses of the itterations.
60%-ring on ring/flat webbing
70%-ring or biner and pulley on flat webbing
90%-ring or biner and pulley on rope or what we call an AFC:adjustable false crotch
95%-homemade RG
100%-manufactured RG
Those percentages could be moved around a few points either way, no problem. The thing to consider is that the advantages of climbing on a single pulley and having [theoretically] zero friction in the climbing system is the epitome, at least this week
Value, like art, is in the eye of the beholder.
What I meant by the clutch not moving is that it is slid and placed when there is no load on the rope. Also. the rope in the RG should stay cleaner than climbing rope. The dirt in the rope acts as an abrasive. At the end of climbing one tree, think of how many feet of rope move through a friction hitch. How much wear is from loaded movement and how much from unloaded?
The shock absorbing capabilites of any of the units from the AFC up in my list could be a big benefit if a climber took a high fall factor drop. Most times arbos don't expose themselves to high fall factors because we keep our ropes snug.
Tom
