So I've always avoided hauling wood, because, well, it's heavy and I don't want to deal with it. I've generally convinced customers to just leave it in the forest, cut it up into firewood rounds (which... some.... get around to actually splitting) or just tell them to get someone else to haul it away who can show up with an excavator and load whole logs into their own truck. But every once in a while I've agreed to haul wood away for certain customers and it's always a pain in the butt, because the only way I can do it is cut the pieces small and lift them by hand into the back of a chip truck which is like chest high, then you have to climb in and push/stack those rounds into the back to fit everything. It's just no fun. So I'm finally looking at other options.
What I'm probably looking at, is a 12x6 10,000 pound trailer to keep it under CDL territory. A dump trailer would obviously allow me a much lower load-floor to put wood in, and I could use my wood cart to wheel chunks straight into the trailer. You can also load over the sides if you don't get a high-side model. I could use it to haul gravel for my driveway, and compost for my garden as well. I sort of don't want to buy an excavator, but a dump trailer with 6-7k of payload would let me haul around a small one that could load the trailer, then you'd go dump and come back for the excavator with the same trailer.
There seem to be lots of brands/models out there, and here is one of my local dealers offerings. The 'Norstar' is the cheap one and I really never buy the cheapest of anything, but it's funny the lightest built, cheapest trailer then gets rated to carry the most weight, as they all wind up right under the 10k limit. The 'Iron Bull' is obviously the heaviest built model at 4,085 empty, a full 1,500 heavier than the 'Norstar'. The 'Big Tex' and 'Diamond C' are somewhere in between, but still on the lower end of that spectrum. Obviously empty weight is only one factor, but I assume it is some measure of how solidly something is built. Though it also takes away from payload and plus or minus a thousand pounds could really affect the options for hauling a piece of equipment in the trailer. Beyond build quality, they are all pretty similar with various features and options.
Thoughts, experiences? If you click the image it should expand to be easier to read.
