What model battery powered saw are yall raving about?
What model battery powered saw should I be looking at for mostly bucket use and occasional climbing. I prune a lot of mature willow oak and live oaks.
For pruning, the T540 or 542’s chain speed will be nice. We have T540s and Milwaukee’s top handles for electric top handles.
For light ground saw the 540 rear handle is great. For removals I’ll use the Milwaukee dual battery aloft, it’s easier to crank than a 500.
Reactions: DGC
I like my Milwaukee.. especially with Forge 8 battery (or Forge 12, but I usually don't get through the 8, so I keep that in since it's lighter). Prunings, not removals.
I don't think any battery saw is as good as the 2511t yet, for pruning... some of the smallest battery saws are very light to carry, but bog in the cut. Seems like an easy inroad for some chainsaw company looking to make a profit.
I'm sure they are all trying.
I was initially hesitant to buy a saw from a "non-chainsaw" manufacturer. Then I realized the "chainsaw" part is relatively easy...when I bought a Milwaukee I was buying from a "battery and electric motor" company instead of a "chainsaw company". Point being: for this tool, it may come from outside of the saws we are used to buying.
Agreed, Kress are highly thought of in that field as well.
Reactions: ATH
Maybe I'm the weirdo, but I prefer just keeping a sharp handsaw for most of my detailed pruning work. I routinely make cuts up to 7cm, and occasionaly a bit bigger. I have the boys send me up a 2511, 201, or 540- whatever is handy- when I need to make a larger cut, but those are rare enough that I don't bother to carry it around all day. I was just in a beautiful trident maple and did half the job with the 6' ARS shears and the boss worked from the ground with my 20' cabon pole pruner. He fell in love eith it, and is now buying his own.
Maybe I'm the weirdo, but I prefer just keeping a sharp handsaw for most of my detailed pruning work. I routinely make cuts up to 7cm, and occasionaly a bit bigger. I have the boys send me up a 2511, 201, or 540- whatever is handy- when I need to make a larger cut, but those are rare enough that I don't bother to carry it around all day....
Absolutely! (well, not "absolutely" to the weirdo part....that's a solid "maybe", but I'm in the same camp with you!)
Unless I have a single cut over 6-7" (15-18 cm, if you prefer ;) ) or a bunch of cuts over 3-4", the chainsaw stays in the truck.
Silky Sugoi is my most used. Silky Tsurugi straight blade/medium teeth (330mm) for structural pruning/tight crotches/smaller branches.
But there is certainly still a place for chainsaws when pruning, and I really like not pulling a cord while hanging in awkward positions, so glad to have a good battery saw.
Yea, don't get me wrong, I am planning to get me a battery saw, and am always watching these discussions closely. I will probably end up starting with Milwaukee, as I own Milwaukee drills, and I would love to have battery cross compatability. Getting a forge battery to be able to crank screws all day, or run a tiny battery in a climbing saw for a cut or two up high sounds neato. When the time comes though, I want a 542i for more steady use/removals.
Reactions: ATH
Anytime you can borrow and try a model of saw before you buy I think it's a great idea. We all have our different focuses and alternate methods of working.
I just spent a couple of days with Brian Bixler who used to post on the Buzz all the time. He said his Omme lift goes out on about every job he does. I would have different saw preferences standing in a lift than climbing all over a tree - for one distinction.
since i bought the little echo battery saw (i often forget it‘s on my harness) i use my silky much less… blades are expensive.
