Are redirect slings considered life support?
Consider it jolt support because if it fails you're going to be caught by your primary tip after a short fall. I'd worry more about the possibly small branch its installed on, presuming that circumstance to require a redirect in the first place.
Consider it jolt support because if it fails you're going to be caught by your primary tip after a short fall. I'd worry more about the possibly small branch it’s installed on, presuming that circumstance to require a redirect in the first place.
If the redirect that failed, only results in a “short fall”, was the redirect even necessary? I feel like a redirect failure would result in a horrendous swing/pummeling…..
Swing on an already tensioned line - OK. Bombing outta a tree (I don't do this usually but whatever) instead of rappel slowly - OK. Taking a whipper of any kind in a work positioning harness, with a work positioning lanyard, with a static rope used for climbing/ work positioning (there's a theme here . . . ) - NoKay. Nada. So to me, if the failure would result in a "fall" onto an un-tensioned tree climbing (non dynamic) line. Oops. ANSI boo boo. So yeah, I'd vote a redirect is life support and should be constructed with rated gear, on a "going to be OK" limb. My 2 cents this AM Stay safe out there.
Addenda to address comment below: by swing I had meant a controlled swing hopping from branch to branch or from stem to stem as you often see in competitions - not an OMG whipper with a slack rope into a trunk that as luck would have it has a bunch of stubs - owww . . .
Swing on a tensioned line back to the trunk from 25' away, at flatter than 45⁰? I really rather not. Redirects are definitely life support when I use them.
Life support plain and simple. The way I am setting up redirects, no slop whatsoever all shared load, at truly flat angles with good distance between them hell no am I wanting to fall into my system and an uncontrolled swing. Fuck that noise. I have broken one or two out pushing limits and it is not pleasant.
Suuuuper unpleasant for sure
In complex trees, more often than not, I will just keep handy a 15m line in addition to my 50m and 5m main and positioning lanyard. I can pout the hook on it or use it as a short climb line, but then rope retrueval is a piece of cake. Three ropes opens up sooooo many options, as a redirect can still be employed.
Good to see everyone twigged to the implications of even a short fall, particularly the possible swing into a branch/trunk aspect, the spinal lurch/jolt etc. Any fall is not good, but the worst is all the way the mother earth. So if you lose a redirect I guess I'm pointing out the mother earth meaning of fall being avoided.
Bet the practicality is 0.01% sling failures to 99.99% tree structure failures in practice. Remember those slings are 23 kN.
Yea, branch failure and not tending my slack well enough account for 100% of my climbing related boo boos. Never been worried about gear failure.
The response from y’all was better than I expected. This is good discussion that gives me good insight and ideas how you redirect. I have some knotted slings I use for light rigging. Thanks Craig
I like things that are holding up heavy moving wood above people and houses to be rated too.
I have never had the the need to speedline anything that heavy. If it's that heavy, I lower it. I also don't use mule tape myself, as I just like all my gear to be rated for silly overkill, but I work for a guy who uses the 1800# mule tape for his speedline slings. For what it's worth, the mule tape that I am familiar with is rated. The smaller stuff I see is rated 1800#, the next size is rated for 2600#, and it's definitely smaller than 1". I don't think we have ever put more than 180# on the speedline, so that's still 10:1
Definitely NEVER rig with gear you don't know for sure is adequate, but don't feel like a lack of a CE stamp is a guarantee of lack of sufficiency.
That’s not that bad. Not great, but not bad. I can see why someone would be tempted. I was looking online for the rating of mule tape and didn’t find it in a quick search.
