Matias
- Butte County
Sweet pick!
Looks like we had similar weather today. I was really feeling great after the recent days in the teens.Glory days of winter View attachment 92268
Very nice!
Those are actually some really good before/after shots in which the light is still reasonably similar. You did all the right things in all the right places. I often get b/a photos and the light is so different it’s hard to see the actual difference.
Shaving the bark is obviously good for wedging as well in your area. Do you guys often find hidden branch stubs when cutting hinges?Nice.
Were you fighting side weight?
Looked unpruned, so little risk of a hidden branch core hiding in the trunk, potentially in the hinge. Shaving bark allows good inspection.
If it was a lot to pull, consider gutting the hinge, a little to moderately and leaving strong corners on a strong, green doug-fir, at least after you have it in the run.
Yea, I had a super weird leaner next to a house the other day- an enormous black oak that died in a fire in 2020- and I wanted to leave as much to steer it, so it turned out thuslyNice.
hard side lean with a lot of weight on the opposite side of the desired lay. I set up so many ropes and pulleys, that we got it on the mark with one man pulling the last pull while I gutted the hinge.I forgot about multiple hinges!! I have done it before, but it was all working according to plan, so I didn't think anymore about it. I have used that trick before though, and will probably think of it more readily the next time the situation comes up. It probably would have given me more peace of mind with how old and rotten the hingewood was on that oak.Would a full- width bore cut or two (triple hinge) have given you more flex?
I pulled a lot of maple stump regrowth trunk s today with full gap faces, which bent over the whole 3" vertical hinge, giving far better hinging than bigleaf maple is known for having.
Lotta tree folding !
View attachment 92283View attachment 92284
Nice.
Well put. Generally delete my prune photos as they’re difficult to get right. Kuddos @Neill !Those are actually some really good before/after shots in which the light is still reasonably similar. You did all the right things in all the right places. I often get b/a photos and the light is so different it’s hard to see the actual difference.
Sizwheels generally engage for us with oaks, even dead ones like that. Sizwheel and a side lines/stay will steer the worst of themYea, I had a super weird leaner next to a house the other day- an enormous black oak that died in a fire in 2020- and I wanted to leave as much to steer it, so it turned out thuslyView attachment 92281hard side lean with a lot of weight on the opposite side of the desired lay. I set up so many ropes and pulleys, that we got it on the mark with one man pulling the last pull while I gutted the hinge.
Sometimes that’s the best way. I dropped a dead pine top over a palm and into the lake one time, because lowering it would have damaged the palm. Plus it’s more fun. ; )Dead pine, plenty of drop zone
