southsoundtree
- Olympia, WA
I'm not likely to mod mine, as I already have a Wraptor.
Any buyers?
Any buyers?
How much do you need for it? (I am not too far from you, in the San Juans).I'm not likely to mod mine, as I already have a Wraptor.
Any buyers?
Have you guys looked at the Ronin Power Ascender?? You can also descend with it. It sells for around $2,000 and seems like a very robust option and definitely way less complicated.You maybe right! check out the first video he made. He was only using the BDB above the device. The device is meant as an ascender only. Once at height its removed and lowered or hung in the tree. Also check out the wrapter videos online. same principal but this device is affordable. I don't see where the disaster you refer to is going to come from. care to elaborate?
Funny you mention putting the ascender above the device... I've got a wraptor I use occasionally, and I always have a zigzag/chicane above the safety rope grab at the top. That way when I get to my spot to work, I take the wraptor off and my zigzag is ready to go no threading or anythingBack in the day when the other "suitcase" style ascenders were available before the Ronin, I fundamentally disliked putting the device in series between me and the rope. I made an electric copy of the Wraptor that looked a lot like the Dewalt/rollgliss but it went under a climbing system. My current Arbscender tucks under your saddle bridge. Point being, I feel it's inherently better to have your climb system on the line above the ascender to take the ascender out of the life support category. It's a design and philosophy decision, but that's my opinion. Hence I'm not keen on the Ronin and the others too. Not saying they're bad, just not for me. You my share the same desire for the peace of mind it offers. If you're handy, jig one up and grab a drill. Voila.
I use my modified RollGliss/DeWalt power ascender this way, with a ZZ/RW just above it as my life support and working rig. The power ascender comes off the rope as soon as I am at height.Funny you mention putting the ascender above the device... I've got a wraptor I use occasionally, and I always have a zigzag/chicane above the safety rope grab at the top. That way when I get to my spot to work, I take the wraptor off and my zigzag is ready to go no threading or anything
In this case I'm tied into the wraptor using is default attachment. The zigzag doesn't get used until I'm at heightSounds fun to have my SRT device above the Wraptor when I use that to ascend. Take the Wraptor off, send it down and go right to work.
The thing I would give up though is the ability to repel out of the tree at any given point in an emergency, as in, : yellow jacket nest, Wraptor shredded the ascending rope, etc, etc.
Yes, the diameter of the sheave directly affects the force needed to lift a given weight. This is simply a question of leverage. Radius of the sheave is the lever. Your question has it backwards unfortunately. Increasing the sheave diameter will increase the force needed, not decrease it.Does anyone know if increasing the diameter of the sheave would decrease the torque force needed to lift someone?
I know it would require cutting off the useless rope guard and welding some kind of rope guide as the rope enters and exits the sheave as well as modifying the shaft to accommodate the new sheave.
I though the rope runner was stainless steel. My rope wrench does not change the color of the rope. I use a rack for washing high-rise windows and this happens to all the ropes but they do not look like the photo I posted. I have never used 3/8 rope before to climb on so maybe it does not damage 11mm and larger rope. I have not shaved off the metal yet to make in midline attachable to test. Anyone noticed damage to their nice ropes from the sheave?I've not seen that kind of damage. I'd definitely check for burrs as mentioned.View attachment 74021I though the rope runner was stainless steel. My rope wrench does not change the color of the rope. I use a rack for washing high-rise windows and this happens to all the ropes but they do not look like the photo I posted. I have never used 3/8 rope before to climb on so maybe it does not damage 11mm and larger rope. I have not shaved off the metal yet to make in midline attachable to test. Anyone noticed damage to their nice ropes from the sheave?
I use a 999 dewalt. There is not a problem with it pulling me up and the break in the drill holds me most of the time when stopping. I weight about 180 pounds.
I was looking at this atlas sheave and noticed how much deeper the rope seems to sit in it.
