Cool setup.
What I’ve seen and adopted is a cinching, adjustable, indepedent canopy TIP that has two rings- a large petzl ring on the end of a spliced 20’ rope, and an adjustable prusik smaller ring. Your climb line goes through both rings like a cambium saver.
I use a quickie and an alpine butterfly 90% of the time unless it’s a spar that will require more than a couple rigs. This separate system has benefits over the quickie/butterfly in that it is-
Removing wear and tear on your climbing rope. Also no pitch on your rope and climbing system.
infinitely and quickly adjustable.
retrievable. Best way is a micro biner sharing the eye of your climb line with your life load biner. Never have to take the lil biner on or off.
Removing the need to estimate the length of tail you will need for the final fell. You just DRT to the ground.
This is something I saw others doing. It was
@Worthaug or
@caleb both.
I dont have a photo sorry
