Yes, that's actually the exact scenario i encountered, one of Petzl's Bridges. I was always under the impression it was 10mm.
GTFO! You got TriTech to pass!?!? Damn! I ended up cutting an eye off of mine to get it through!! Maybe i didn't try hard enough.. i probably should have anchored off & pulled like a mad man..
Two side notes regarding lanyards -
1. Does anyone have a good source for industrial sewing that will sew an eye on a USED lanyard?
2. Has anyone elses experienced extreme milking on their CE-Lanyards/HipstarFlexs'?? My 10 meter probably has 2-1/2 extra feet of cover trapped in it!! It makes the hitch cord bind up constantly. Obviously I'm aware two ends being terminated can lead to this, but it's as if there was already a TON of cover slack in this section of spool to begin with & no one took the time to milk it before sewing. I am an avid splicer so I'm aware of what's normal regarding cover slack & whatnot, but this is just crazy, i can barley use the last 7-10ft of the lanyard. This is the second one too, first did the same thing as well... I just expect more than this considering the cost & i don't want to give up the eye. I want to cut, milk & have it re-sewn, hence my first question.
