A statement based on the assumption that if you don't reach a system's MBS, it is somehow less relevant?
My statements are specifically addressing the default mindset of 'pull-it-till-it-breaks' - and the relevance of doing this. If you take a snapshot of all of the knot tests performed all around the world - they invariably all run the same theme; 'slow pull-till-it-breaks'. There appears to be no other way of conceptualizing how to test knots.
Virtually everything we do in this aerial-access industry is based on knowing and working within a safety zone.
Every roping industry states the same thing.
It is sufficient to state (and assume) that all hand tied knots in a modern synthetic rope will reduce the MBS of that rope by 50%. Regardless of knot choice - even the alleged 'worst' knot, 50% reduction factor covers them all.
As a thought experiment, I could happily use #1046 (Overhand loop knot / Overhand eye knot) as my default end-of-line fixed eye, and still meet this 50% reduction factor. Of course, all of my knots will jam - but for the purposes of this thought experiment, it is simply to point out that the simple and humble #1046 will meet all safety requirements.
Knowing where a knot fails or what strand of the fiber gives way first will change nothing for the field worker.
This points to the fundamental premise behind the entire crop of knot testers around the world. What exactly are they trying to prove? When they conduct yet another default mindset 'slow pull-it-till-it-breaks' test - what revelation has been uncovered?
We could save them much time and effort by simply declaring all knots to reduce the MBS yield of a rope by 50%. Even the alleged 'worst' knot still meets this 50% criterion.
My point - which you missed - is that if you are going to perform a default 'pull-it-till-it-breaks' knot test, you must have a clear and concise stated objected - a reason why.
Several funded research teams have attempted to pinpoint the precise location where fracture propagates from within a knot structure. It has been attempted on several occasions by different scientific teams. None have been able to pop the champagne cork.
So this is one reason for performing such a test - to try to advance our collective scientific knowledge in this area.
For the average roping industry worker - it doesn't mean much. It is pure theoretical research to advance our understanding of forces within a knot structure. And this type of research can pay dividends for rope manufacturers who have the ultimate goal of building and selling a better rope
The other reason for 'slow pulling-till-it-breaks' is to probe the effect of geometric changes within the knot structure. For example, the jury is still out on the effect of adding 3 rope diameters inside the nipping loop of a 'Bowline'. Tests could be designed to investigate this further.
I might also add that virtually all knot testers around the world appear to follow the same mindset of '
slow pull to failure'. They typically use a hydraulic ram of some sort which has a defined 'stroke' (travel) and cross-head speed (rate of pull).
Rarely do you see dynamic style testing of knots - where sudden injection of force is applied.
If you stop and think about it, dynamic load tests more closely mimic operational reality - in that if something went wrong while working at height, it usually results in a sudden injection of force into a system.
I have yet to witness a falling climber fall in slow motion - at the cross-head speed of a hydraulic ram. Or perhaps for this forum, an out-of-control falling piece of tree vegetation - falling at the minuscule speed of a hydraulic ram.
At least the committee behind EN892 (for rock climbing / mountaineering) got the basics right - although the 80kg limit for the test is coming under increased scrutiny (and that will shake up the rope manufacturing industry). The committe behind EN1891 also require a (smaller) drop test...
Within my lifetime, it is difficult to see any changes to the default paradigm behind knot testing. The status quo will prevail for some time to come. Although unlikely, some knot testers might have a lightbulb moment and begin to investigate something other than the 'slow pull-it-till-it-breaks' mindset. Worthy objectives include (but not limited to); jamming threshold, instability threshold, the effects of slack shaking and cyclic loading.
I once came across a famous philosophical phrase:
“All truth passes through three stages: First, it is ridiculed. Second, it is violently opposed. Third, it is accepted as self-evident".
