Knots for joining two ropes for life support
Came across this article. Does this look like what you're referring to with the retraced 8 but without the bite?
I am not entirely sure if it is the same, however a quick google search has allowed me to come to the conclusion that a flat 8 is very different (and dangerous) then a figure 8 (flemish) bend. My resources are from a quick internet search so take it for what it is worth?? As far as I have been taught and through research the figure 8 bend is very popular and a very strong way to join similar sized diameter of rope
Just a flat overhand knot with both ropes works just fine for this application. Rock climbers use that knot all the time for joining ropes before rappelling. It is often preferred for this because it stays flat and doesn’t hang up on edges as easily. This is referred to as the European Death Knot but that is a misnomer.
Double sheet bend is another great one and one that I use a lot for this application.
Double fishermens is strong but can be difficult to untie after loading.
Didn't you take SPRAT a few years ago? What was their preferred method?
A properly tied, dressed and SET EDK,
not that flat 8 on icy-ropes,
is a winner.
I'll butt a second over-hand with both ropes up against the EDK, if I'm not super-impressed with two different constructions/ sizes of rope mating up nicely. It can't roll. Just a bit higher profile, while remaining, importantly, asymmetrical.
I'll sometimes use a 9mm HTP tied to my 1/2" line to reduce bounce, and sawing at natural crotches with thinner bark, when base-tying tall trees.
Had to look up the Zeppelin bend. Thought it was the same as the Hunter's but the copy specifically says it is not. I'm a big fan of the Hunter's and would use it for life support without any worry. Learned the Yosemite bowline from Jepson, always breakable even when loaded heavy, fantastic for so many applications. For heavier rigging the bowline on a bight can be easily undone after insane tension, but that's a bulky one in your situation. I would also consider a Carrick bend if the tension remains constant once set. Bends like Carrick and sheet bend hold up okay if taut but if they're slacked and shaken they slip. Gonna try the double sheet-bend with dbl barrel tie-offs, I've never tied it that way, haven't tied sheet bends in awhile.
The two DFL option in this situation (I'm seeing a grapevine knot when I think 2 DFL's) wouldn't be my choice because I've always found it tedious to undo after even moderate loading. Figure 8 traced, I hear it's a go-to for rescue operations... It would take me too long to tie that, I never do those.
Really cool suggestion to insert a fid to keep riggings less tiresome to break. I haven't yet learned to splice, I don't have any fids, but I'll search for more info on that.
It’s a makeshift fid - I use a dead stick usually about 5/8 inch to inch diameter without stubs (smooth) so can pull out easy and disassemble knot easy...
I've used the stick trick a few times, I've found that it doesn't really have to be smooth because you can break the stick inside the knot and remove both pieces. But doing it this way does require it to be a stick that's fairly easily broken.
Kind of off-topic I know, but the surgeon's bend, as a rigging bend the way I learned it (pic called SurgeonsBend) is excellent for being breakable after heavy loading. I learned it as right over left, twist both ends in opposite directions 360* until 4 intersections are formed. Then switch order and do left over right, repeat, twist both ends simultaneously 360* in opposite rotation, forming another balancing 4 intersections. Then set tightly and balanced.
Not to say that it's unsuitable for life support, but it needs to be set very carefully in critical applications. The pic called "SurgeonsKnot" is not what I learned from Morrow, but I'd use it for utility connections cause it's super fast. Same idea when tied on a bight is a surgeon's loop. Pic called Step4 is yet another variation.
1/4" to 3/8" stick would possibly be slack enough to until.
Choose a dead stick with enough solidity to not be crushed and broken, but can be bent and broken.
59750
I recently had to tie two ropes together because the tree I was in was just a bit too large, I used the zeppelin bend and then tied off the ends with double fisherman's to back em up, worked great! Of course I didn't sinch the double fisherman's super tight so they could be Un done easily.
