Z'sTrees
- Hartsel CO
Tim,@Z'sTrees; I was wondering whether or not the Bola is at all "jerky" when you go to release it with your full body weight on the line. I own the ART Positioner, and maybe this is operator factor, but I do find the release to be rather sudden. I've taken to pinching the rope with my hand below the device in order to provide a smoother release.
I guess I'm just wondering if the Bola seems to operate in a smoother fashion than that, without going to the extra lengths that I do with the ART device. Thanks in advance for any answers you choose to provide.
Tim
I find the bola to be perfectly smooth and controllable as a lanyard configuration. When in ddrt mode it can be a bit less so depending on the friction of the tree. Single leg takes more effort to release so if you dial that force up slowly and don't just reef on it it's pretty darn smooth. All this is with the Yale r.i.n.g. 10.5 mm line. When I was using tritech (a good bit fatter and stiffer) it wasn't as good drt/srt but still very much adequate.
I found the art positioner to have the same issues you're saying. It'll release under load but there's not much control. The zillon seems like a nice piece but lacks some of the versatility of that the bola offers, in my opinion.
Interesting to add a wrench in above the bola, I just don't think it makes much sense to try to make it into a true climbing system when there's a fantastic and very similar device that's designed to do just that, the bulldog bone.
