I have mixed feelings about the CID. As far as performance goes... for a 37 hp machine, the damage that you can do is mind boggling.
The first job that I put it on, I caught a 4 ft. strand of barb wire. Wrapped around the output shaft and cut the bearing seal. I had asked about bearing seal protection before I bought the unit. They sent some seals and designed a shroud for bearing protection (which should have been on the unit to begin with. It's a BRUSH CUTTER and fence wire is a given) but only offered to pay $100 of the $350 that my dealer charged for the repair. Two months later, gave a 1 star and an honest account of the experience on Google and they call me the next day apologizing and tell me my check is in the mail.
The CID is an acceptable unit. With the cutaway design I can cut down a 6 in. Pine tree no problem, but you can't efficiently mulch a tree that size so it is a bit unnecessary. The cutaway allows sawdust and small chips to spray from under the deck and on to your machine. Not a big issue but I suspect I'll have to clean it out one day and you know how much room there is under the hood of an 850/1050.
It also weighs 675 lbs. Not a problem for the 850 but I think it puts unnecessary wear on loader linkage and track roller bearings. If I had to do it over again, I'd probably buy a Quick Attach Mini Brush Buster. It has similar performance, better fit and finish, the blades are just under the cut away (minimizing scattering debris), it only weighs 420 lbs., and they will stand behind their product.
If any of you have any more questions feel free to email me at
wesp5284@yahoo.com. I have a good bit of industry knowledge on this type of machinery.
