I have a new toro tx1000 and just received my new bmg. When I hooked it up the hydraulics open and close super fast. Any way of slowing that down ?
Looks like you got your answer, we sometimes do this, usually a 2mm orifice. If you can’t get one off the shelf, we tap out a 3/8” nipple & loctite a drilled grub screw in. Make sure it’s in well as you don’t want it slipping into your cylinder! It generates minimal heat as it’s not a constant flow tool, like a trencher going through a restriction. Also possible to get more technical - put in adjustable pressure compensated flow control valve but I like simple!! Cam
