So guys, I have a question... for those of you that are using a Tree-Mek, what type of more traditional tree crew do you think would be needed to equal its time to remove a tree? For example would you need a crew of 4 guys, a crane, and a bucket truck? Or maybe just a 100 foot stick Crane with a 4 man crew? Or how about a setup like Mike Poore with the remote control knuckle boom, a climber controlling it and then maybe a mini skid, or articulated loader feeding the chipper on the ground? I am just curious. I realize part of the beauty of a Tree-Mek is being able to do it all with only a two man crew.
That is a tough question since there are so many variables, but I'll try.
Before the tree-mek I had a 75' rear mount elevator that I would operate and 2-3 guys on the ground handling the rigging and clean up. I think the best way to answer this question is to add up all the time spent doing things that you don't have to do with a tree-mek then add up the expense of the 1 or 2 extra employees.
Here are things u don't do anymore. I don't put on a harness, climb into a bucket, climb, set up a portawrap, handle a rope, set a rigging point, tie knots or use rigging, make a face cut, make a back cut, move a rigging point, wait for guys on the ground to move limb or log, untie rigging, and send rope back up, estimate and communicate how many wraps to use, use a saw and run out of gas, come down, refuel, and go back up. There's a lot more, I'm sure. I'm sure you're starting to understand.
Its just so simplified. Very little saw use. Very little clean up. No impact on the yard. Easy to load logs. Less men to depend on. Less equipment to maintain and coordinate.
If you build a tree-mek, it will change forever what you think is a day's wage and a day of work. Hopefully, this gives you some idea of what it's like.
