when you are positioning yourself in a lowering(snatching) situation you have two options on installing your lanyard and your climbing line in relation to the lowering block.
1. lanyard above the block, climbing line(or frictionsaver) choked on the trunk under the block.
2. lanyard under the block, climbing line(or frictionsaver) choked on the trunk above the block.
what would you recommend as the best or safest setup??
climb safe, Jelte
climb safe, Jelte
