- Upper California
I purchased a Notch 3 pole set with blade head and blade as well as a set of 2 Jameson FG poles, all hollow. The two brands fit together fine. So I have five 6' poles. It is awkward but manageable to use 4 lengths, 24'.
I had one pine branch that was about 34-35' up that I couldn't resist. I got it with the full 5 pole 30' but it felt two iffy to try it just holding the poles. So I cast a throw rope over a higher branch, pulled up a heavier rope, attached the saw end to the rope, pulled it up, and tied the bottom end of the rope to another tree. I also did this for safety. If I lost control of the poles the rope would support it. I left enough slack to cut the branch and it worked fine. Helps if you get the hang of when to raise or pull depending on the flexing.
I may get a saw blade with a hook end to keep from pulling the blade out of the kerf on the down stroke. Not easy to get it back in when it's higher up or to see where it is in the cut. Pretty sure Fanno blades will fit the Notch saw head. Not sure about Jameson.
Going to glue the rubber cover onto the end of the Notch base pole. Kept slipping off.
