I have a Stihl MS310 with a 20" bar. The bar is newer than the saw, replaced with an Oregon bar around 2011. I swapped in a new bar precisely because I am having this problem.
My chains are SHARP, they throw spaghetti and huge chunks at the beginning of the cut. Just the other day I was bucking some felled maple. The saw starts cutting perfectly, gets about 4 inches down into the log... and then the wood stops flying and the saw loses it's "bite", and it's as if the chain is dull. If I start a new cut... same thing. Great performance at the beginning, then it behaves as if it's dull. I try rocking tip to hilt, and wiggling to try and re-set into the cut. It's very frustrating!
I really don't need the expense of another saw right now!
- The chain is tight and sharp
- the saw is throwing oil
- the bar is periodically maintained, i.e. cleaned, filed along the sides to remove any bur or mushroom caused by use, and also flipped every time the chain is replaced.
- the bar does not appear to be warped or bent when sighted from different angles
