Heat treated aluminum alloys are plenty strong... it's when the the process goes wrong that you get a weak part. That can happen with ANY metal and that's why proof loading is the best solution.
I know it happens but I've never seen a piece of broken aluminum hardware, that is, snapped right in half with no warning signs. And I've used lots of it.
When you get into Strengths of Materials the math and terminology get confusing unless you're a practicing engineer or physicist... and I'm not so I can't get down and dirty on this. It's been decades since I've done structural computations.
But, it's fairly obvious that a piece of metal hardware designed for life support should not break without warning and it shouldn't break under even a high dynamic load from body weight. Something was wrong with those Kong rings and it should not be a reflection on the typical strength of aluminum hardware.
Titanium rings are cool, I might buy one just to say I have one... since I'm a gear weenie and all. But I'm using rated aluminum on my bridge right now and I'm not worried about it. Most of my biners are aluminum, my snaps are aluminum, blablabla. It's good, tried and true stuff.
Titanium has a killer strength to weight ratio, but they compensate by making smaller, lighter pieces, The Safe working loads for similar uses are not much different from aluminum.
Time for another thread on working load because that's become foggy through all this...
And one last thing I should say about the Treeflex harness... Knowing what i know now, I recant without equivocation my statement about having no confidence in the harness or the designer. I made that statement based on a lack of communication from the maker. I trust the CT rings and I trust the design. If I wasn't so stinking happy with my BFII I might just buy one.
