Rig N Wrench one way pulley problem
I was using the one way Rig N Wrench yesterday (wrench not engaged) and was using it in the opposite direction that it's intended (when the rigged piece was run to the ground the pulley would run freely and when the rope was pulled back up to me, the pulley locks). That's what the set up called for so that the spring loaded pin wouldn't bump against the tree. After using it I found that the one way feature of the pulley seized up. So now the pulley acts as just a thimble essentially. I may have side loaded it a bit I guess. Or was this one way pulley never meant to be used in the opposite direction? Anyone else experience something like this?
