tc262
- SE Wisconsin
YesSo, if Im following correctly, you were right, it would be loose, under 100 lbs.
So I would check the torque here:
NO!Then adjust here ?
Mine got noisey and it turned out all the teeth were gone off 1 of the fibre disks. What engine you have? The pilot bearings are known for wobbing out the flywheels on the deers causing alignment issues. Foley engines in worster mass has everything you need in stock way cheaper than dealership. And will overnight it right out. If its noisey something is worn or busted
