Are you asking me? The set up I did a mesh tarp roof with was a dump insert on my f250 5x8x4.5(tall)
The biggest issue was chips blowing back out on the rebound and dust clogging the radiator in the summer. The mesh tarp helped with the rebound and cut the dust blow back (but the dust just went through the mesh and over the cab). This was the motivation for buying a leaf blower. But I’m considering doing it again! Now that I have two chippers I can split off and so some small stuff independently from the crew.
However I’m also considering a dump trailer, for blowing chips into. Currently my mini hauler is a 12’ flat deck equipment trailer, and I want to use the mini to push the chipper and trailer into a yard to chip into.
I’ve used the flat bed as a log hauler and brush hauler powered with the mini. So the next thought is use the dump insert on the flatbed instead of the pickup. It’s not out of the realm of possibility I can plumb flat face connection onto the dump hydraulics.
The dump insert are rams not cylinders, electric over hydraulic, held in to the bed with 4 bolts, it’s light enough the mini could take it in and out of the bed if the truck and slap it onto the trailer. I’d have to fab pins and a plug for the electrical if I wanted that versatility. As is right now I bet I could swap it in about an hour.
