Hi, I'm the inventor of the M-System. It was interesting to read these comments so I've joined 'the Buzz' to answer some of them.
The M-System enables you to climb in the most effective way possible. It's so easy to climb that a ladder would be hard work by comparison!
Far from being gear intensive, it's actually simpler than other rope walkers and takes only a few seconds to set up. I'm working on another version which is simpler still.
Because one mechanical ascender on the rope is not enough to meet safety requirements, and to make it easier to switch to descend, I have tried it with a Rope Wrench as backup. It works really well.
To descend I moved the lower ascender up, stood up on its stirrup while raising the Wrench up, then sat back on the Wrench and removed the ascenders. That's one option - I'm sure there are others.
(The stepping over obstacles demo would only meet safety requirements if there was a seperate line with a fall arrester, as in Rope Access work.)
I plan to demonstrate the M-System at the Treeclimbers International 30th Anniversary Event in Atlanta in October. Hope to see some of you there.
Any more comments will be really appreciated.
Michael
