- balancing on the edge . . . .
Wanted – Seeker of throwball: Must have keen sight to spot pink and orange items on the ground. Item is somewhere in the state of LOST.
http://seamorelilfoot.smugmug.com/gallery/4277206#250563133
Applicant must be able to hike along a concrete wall that forms a stream. Crossing at low water levels is suggested. Must be able to hop a three foot wall to get to the ground and bushwhack into hedges and brier bushes, brier can be avoided if you walk along the wall for another 5 foot.
Applicant should know what a throw ball looks like. This one is 14 oz, dipped in pink rubber and orange at the top with chrome colored ring. Item was lost on Super bowl Sunday. About 3 pm.
Item is in or near a LARGE, 15 foot circumference Sycamore tree. The item was tied to a zing-it line when launched into the air, when the owner pulled the line to retrieve after a bad throw, the said throw bag was missing.
The tree, easy to set a line in, easy to climb does have one thing that the applicant must be aware of; there is PI in the tree. The original climber removed what could be reached and cut major growth from the tree and from around the base.
Applicant should have the knowledge to and be willing to climb on rope, with approved PPE and have own equipment to see if the item is still there. Applicant will be escorted to the tree.
Applicant, if item is found will be rewarded with lunch in place of payment for services. If item is still amoung the lost, applicant will be rewarded with lunch in place of payment for services. WF is also available
Contact the poster if you are interested in applying for this temporary position.
