If you get every job that you bid, it is too little. If you are getting most jobs, then likely it is below market value.
I was just remember a job when I first started out. I had one climbing saw and one MS 361 to do the rest. When I was blocking down the spars in double and triple firewood lengths, the groundman could only move the large rounds out of the way, barely, then he would wait for the next one. High efficiency was not present due to skill building and equipment shortage. Therefore, productivity was not as high, therefore, while I was too cheap by the job, our hourly production maybe was somewhere around what you are talking about. This was legally operating, BTW.
Three years later, I have two climbing saws and four ground saws. Rather than an completely inexperienced ground crew, my employee(s) get thoroughly trained, and I try to hire multipurpose crew members rather than a groundie only, even if he predominantly does ground work.
You would be better to get a lesser percentage of your jobs, made up for with higher profit margin. Even if you make a little less money, it will be less wear and tear on your body and equipment, and you will be able to put in that little bit more to each job that will help your reputation.
Make sure you are giving out business cards like water, and ask for written references if you can get them, take photos of before and after, and put them all in your bidding binder with your insurance paperwork.
You don't want to be the cheap guy.
You want to set yourself up as a good value, and reliable. In time, you will get the second round of work from customers, in a year to many years of being in business. You will want your repeat customers to be looking for value over cheapness, and their referrals to expect not to pay the least, but to get a good value for quality.
The hard part is determining market value, which changes all the time, IMO.
Best of luck. Scratch that. Best of hard work, dedication, blood, sweat, and tears, reading all the archives of the business management forum for the last seven (or is it 8 now) years, asking questions, and if you can sneak in a college business class here and there, it will help.
How long in business?
The very most important thing that Sean said was value. Always try too promote yourself as the best value around and you will never be expected to provide the very lowest price, just the best job for a reasonable rate.
