treebing
- Detroit, Mi.
What I have been doing in the past couple of weeks is this.
I took my big buckingham frictionsaver, then I put the A.R.T. pulley (60$) on that using a prussic.
I found that the big webbing made it a better rope guide. when on regular rope, I had it on a 16 stand, the rope and prussic would bend and try to cram itself through the aluminium ring, then removal was made very difficult. The big strap solved that problem for me.
whats also cool about it is that it can be both ring type friction saver and a rope guide. I can set it from the ground, work the tree, and then when I find myself next to the set up, I can switch it over to the rope guide application. less friction.
Working spars it works great too but it is a little short to go all the way around the bigger wood. Then I just take the ART pulley off the strap and put it on a longer rope with a ring or even a carabiner at the end is great.
I have also found that when setting the rope guide on a spar, If I put a carabiner on the big ring and put the pulley through that, I don't have any trouble pulling it out. This is because the caribiner changes the angle and does not pinch the ART pulley against the tree when you try to remove it.
That is really why the rope guide is awesome, because you can set it on a spar where there is no crotch.
As far as nailing it against the ground, when over concrete or other nasty surfaces. I like to Take it out before I hit the ground and decend in two stages. this is helpful too because it leaves you in the tree in case anything gets stuck. And that happens in this work occasionally.
