southsoundtree
- Olympia, WA
What condition are the battery cables in?
YupIt is a twin disc cluth not an auto clutch. So engage it at idle rpm’s? Slowly until things start turning and then bump it in?
Call the dealer for a manual. Might be online.
Drain that oil and change the filter, if you're that low, IMO.
Is there a hydraulic fluid 'eye' or dipstick? Is the dipstick broken off the cap?
Morbark don’t make enginesI called Morbark and they gave me a manual as close as they could to my model year but there are no PSI specs on oil pressure.
I will change out fluid, might as well right?
No dipstick so I will just jimmy something up to check it. Thanks for the reply.
Does anyone else know what oil pressure should be reading? Thanks
Where is said safety button?Alright guys. My apologies before hand. I did not even think to see if the safety button on the rear of the chipper was pushed in or not. I finally got a chance to start her up and figured I would check that before anything else. That was the issue. Fired right up and let it run for a bit.
Now... Can anyone give me any tips on engaging the PTO clutch? Is there a certain RPM I am supposed to engage it at? Am I listening / feeling for a "bump" before I engage? I do not want to ruin this thing right after I got it.
Thanks a lot!
That depends on your chipper. Not all chippers have one, if you can post the model and year someone here might be able to tell you where to find it, if your chipper has one.Where is said safety button?
It’s a 96 model 200. Cranks gets fuel and spark won’t start. Started an hours before hand now it won’t. Makes no sense and has to be something dumbThat depends on your chipper. Not all chippers have one, if you can post the model and year someone here might be able to tell you where to find it, if your chipper has one.
If it’s a 96 model 200, it won’t have a safety button at the back. It probably doesn’t even have a safety plug on the disc hood, but it might. If so, it will look like a trailer light connection with just a male plug end stuck in it.It’s a 96 model 200. Cranks gets fuel and spark won’t start. Started an hours before hand now it won’t. Makes no sense and has to be something dumb
