I must be different in the USA I don't know, but here one reason why we have legislation intended to prevent door to door pressure sales is to remove the opportunity for unscrupulous characters from exploiting the vulnerable.
There are a whole range of problems with these door knocking "companies" many are unregistered, unlicensed, uninsured, and unqualified. They don't explain these things to the person who answers the door...nor the consequences for the property owner if something goes wrong during the job.
You and eric whinge about the door knocking and licensing issues but the report was focused all on price. Price is set by the end consumer. They have the choice to take it or not.
Private people will always have the right to spend their savings as they see fit, but perhaps if you ponder on this analogy;
A door knocking motor mechanic tells your aging father or mother that they were just passing and noticed the car in the driveway has tell tale signs of brake failure. Now its lucky cause they are in the area to do some brake work on a vehicle round the corner, and can fit them in but it has to be today and in the next 2hrs....cheap rate for them.
$500-$1000 later they have had their pefectly safe and operational car tampered with by an unqualified idiot who wouldn't know the brake hose from the battery lead.
Now it is the nature of analogies to be somewhat inadequate ways of getting a message across, especially since there are numerous differences between tree work and car machanics.
yes, they are different. Knocking palm bits into one's yard and then hauling them off ain't rocket surgery, sorry, but it is not. You don't need arborist cert to get that done. You need a chainsaw and a 3rd grade education...common sense would help too.
And it is way different than servicing a car's critical systems. Plus, what if I want to pay a door knocker $30 to change my pads or trim my trees? Sheesh, what happened to freedom?
