Muggs
- Canuckistan
I'll go up and drill one side, measure cable length, then cut ehs with angle grinder on the ground leaving foot or two extra length, install a rig guy on one end and go up and install cable on the drilled limb end pulling cable right thru, then install other end (use a come along and wire pull to move branches closer together a bit) .
Ed, I like that, installing the one rig guy on the ground. Makes a lot of sense, I'm going to try that. What are you using for a wire puller?
