Serf Life
- Maine Island
Who uses them around here? I’m looking at a POS 4 stem red maple next to a house which is a candidate but I’ve never installed or inspected one.
That sounds like a good way to install.What we usually do is connect all four cables to the hub first, leave just a bunch of long pieces of cable, and then hook the ends up and shorten the cables as necessary.
This is what my first plan was. I wonder which would have less chance for failure?Sometimes you can just install two cables in those trees though, in an X pattern, and get the same or nearly the same benefit without all the extra work of the hub
The center of the clump is a rotten mush from a previous lead breaking years ago. My understanding is that cabling across is preferable if the union is compromised.Is it possible to box cable the tree?
I was thinking the rigguy hub but the ring setup would allow more flexibility in angles. Any downside, assuming thimble and cable wraps?The hub was a crane rigging ring
In my opinion, it comes down to that kind of support you are looking to provide, and how bad the tree is. Using the hub means that force on one stem is shared among all three others, and in my thinking, using a hub permits more lateral movement among the stems, where an X pattern may not quite so much.That sounds like a good way to install.
Add some brace rods.The center of the clump is a rotten mush from a previous lead breaking years ago. My understanding is that cabling across is preferable if the union is compromised.
Does the tree have inclusions? If so, I would follow the A300 as best you can.Who uses them around here? I’m looking at a POS 4 stem red maple next to a house which is a candidate but I’ve never installed or inspected one.
I will probably hit it with some black spray paint next time
