A few questions -
Time of day, last time precipitation occured, how soon did it again occur (after spraying), was the oil 'pH'd?' to buffer it, how heavy the application, and additives?
Right off, I'd say it was an issue of phytotoxicity, but that's usually a sequela to the above questions and their answers. 90 is hot, humidity isn't as important as sunlight effects, and the possibility of "drowning" stomata is high in conifers - 'specially in heat.
Another factor often overlooked - the spray rig and what else it's used for and how recent and often. Phenoxy compounds remain on pipe walls, filter screens, pump and tank surfaces and adhere to rubber and plastics, released under surfactants or soaps. Same with organophosphates, residues not concentrate enough to smell, but strong enough to kill. Also spray rates...as oil's accumulate and drenching can often seal too effectively. Watch those guys who apply and see how heavy they spray things.
What were you after with the oil?
