Brando CalPankian
Carpal tunnel level member
- Pine City, MN
It's an f350? Sorry I'm not sure what you mean.What would that put payload at on that pickup?
I was planning on cutting off the sides yeah. It's going to get slimmed down a bit. The price was right and if I'm going to cut it up might as well not buy something too nice. LolI'd go with steel again.
Are you going to keep the fold down sides? If you're not going to use them I'd cut them out to save weight. It does look heavy
I think he means GVWR if I’m not mistaken. My 99 f350 is 9,900lbsIt's an f350? Sorry I'm not sure what you mean.
Correct. The stock bed weighs about 500lbs. It's not going to be a big chip truck. It's more for pruning/getting closer to work in yards/hauling equipment/being under CDL for second employee. I wanted a crew cab dump. If I could have found an f550 I would have, future planning. For now that's my plan. It'll handle what I need it to.I think he means GVWR if I’m not mistaken. My 99 f350 is 9,900lbs
Right, what the rated capacity the truck can carry, minus the empty weight of truck to get payload. For example my previous 2500 chevy had 3381lb payload capacity stock, 8’ slide in dump insert with plywood chip box ~1000lbs, makes for about 4yd chip capacity.I think he means GVWR if I’m not mistaken. My 99 f350 is 9,900lbs
You have to consider rear axle weight as well as gvwr.It's an f350? Sorry I'm not sure what you mean.
I'm not planning on making it a big chip truck. I really want it to be able to handle small pruning jobs, planting, stump grinding, equipment hauling etc. Can you expand more on your concerns? I appreciate the input greatlyYou have to consider rear axle weight as well as gvwr.
This is something I've had in mind. Metal moves for sure. I haven't figured out the right amount of space yet. Was thinking 3-4".Make sure you have enough space between the cab and the bed to allow for flexing. Saw a guy mount his flatbed too close and it hit the cab every time he transitioned from streets to driveways and other uneven places
