Got a pin hole leak in a steel line today. Tried the vice grip crush/plug to preserve the other 3 wheels - failed first attempt, folded the tube 2nd attempt, brief success - then it failed too. So I limped back to my garage to replace the line. At some point it seems to me the industry changed the design of master cylinders so you can't gravity bleed the system. I guess to prevent fluid loss with an unknown leak as you drive. It seems you're stuck with the pump/crack assistant method but I tried my luck today with the vacuum method. You use a hand vacuum pump with an intermediate jar with two hard lines soldered to the lid as a vacuum reservoir and fluid receptacle. The other extra is remove your bleeder and use stiff grease like dielectric on the threads only and you won't suck air via the threads. The silicone stays out of the hydraulic circuit. My Dino uses DOT3...
I was pleasantly surprised to get my pedal back after two whooshes of bubbles and fluid with no assistant. Repairs usually put up more of a fight.
