CAn anybody tell me why one is called a block and the other a pulley?
Thanks
Greg
Greg;
If I understand the question, you are not asking what the difference is between a block and a pulley, but why there are different names.
In Arborist Equipment (p. 180), Don Blair offers this:
"The terms are interchangable as far as this book is concerned. Early pulleys consisted of a sheave or grooved wheel mounted on an axel between two blocks of wood. Called pulley blocks, they've been abbreviated in both directions." I think the phrase "...in both directions..." means that sometimes the term 'pulley' is used and sometimes the term 'block' is used.
Although Blair states "The terms are interchangable..." the rest of his text seems to adhere to slightly stricter definitions.
Most, but not all (eg. the Petzl Fixe) pulleys have rotating cheekplates. They are meant to be used for light duty work and require a connector (carabiner, screw link etc.) to attach them to the sling. They are often categorized by the diameter of the sheave.
Blocks may also have rotating or fixed cheekplates. What distinguishes them from pulleys is that they are constructed of thicker, heavier material and do not require a separate piece of hardware ( a connector) to attach them to the sling. The attachment is achieved by placing the sling over what looks like a small sheave on the top of the block. This small sheave is called the bushing, which can be confusing because the (main) sheave rotates on bearings that are either ball or, more often, bushing bearings.
Arborist blocks are manufactured to withstand heavy dynamic loading and have extended cheekplates to prevent the rope from rubbing against the tree.
Blocks are often categorized by the width of the tread of the sheave (i.e. the largest diameter rope that will run over the sheave). Thus a 5/8ths inch block sounds smaller, but is actually heavier than a 4 inch pulley.
Mahk
