Ripping thru can work well, gotta stay in it's safe range.
Can disrupt fiber into parent though; so if preserving tree/ is a consideration.
It does not provide a path of least resistance into open face;
It does not necessarily keep everything 1 piece simple on the hinge,
>>so not having competing parts jamming against each other
It does not (necessarily) fold from stress to wide hinge, can focus pressures to almost a point
It doesn't always use inner rings, many times peeling off just outer rings
>>less substantial than the 'welded mass' , but can be more flexible.
Are some of the assumed mechanical trade-offs made doing this;
so i'd use very judiciously, not across the board (so to speak)
i maid this around early 2000's(lil'ruff),
trying to show sideways swing dutchman(tapered hinge up/pull side, dutch kerf under/push up side) rigged theory
(previously posted about above; knew i had this some place!):
mytreelessons.com/horizontal rig.swf
then extends theory to noFace / rip across with dutchman theory.
Drawing( older vintage '90's) showing taking dutch step 1 side + tapered hinge= swing dutchman turned sideways into tree rigging
http://www.mytreelessons.com/images/sweep versus fall-step 1.jpg
Warning: This is getting far into theory of using powerful forces to maximum. This strategy uses Dutchman Forces in an early closing of the Face on 1 side; that legend and lore has warned against; so is for enlightened discussion purposes only..
(if vertical cut bypasses horizontal, close is across fiber stack flexible axis
if horizontal cut bypasses vertical (to fiber orientation) close is 'up' thru fibre stacks
'roman column of strength' is a stop/ not a flex across bendable axis of fibers!
reference previous post drawing showing horizontal or vertical cut bypass comparisons)
Usual accidental dutchman of horizontal face cut bypassing the more vertical cut;
kerfs across full face, providing full stop or shear mechanical command.
Step Dutchman ,
gives block or kerfs heavy side only to push up,
offers rest of face as path of least resistance,
allowing forward force flow that a full face kerf blocks can command to BarberChair.
.......orrrrrrrrrrrrr sumetin' like that!
