[/ QUOTE ]Has ANSI decided to throw out the first rule of cabling only structurally compromised limbs?
What are you talking about? I do not see that wording in there. Paraphrasing just confuses things--quote the clauses that you have problems with, and state your suggested changes. If your comment is based on a wild scenario, like people and property being saved by burning broken tree parts that are held together by solid steel, it may be met by skepticism.
Still waiting for that helpful comment you're giving the committee there jon...and waiting...you speak of ANSI as if it were a person--what do you mean by ANSI? please reread:
For clarification on unfamiliar sections, look again to the Definitions. See how the concepts fit together, forming an integrated structure. If they don’t fit, consult a dictionary or thesaurus to get a wider context, a better view of the meanings. Consult with a colleague, a chapter member, a mentor, a local expert, to see if they can help sort it out.
Visit
http://www.tcia.org/standards/a300.htm to see when that Part is being revised. Public comments are always welcome, but they are best understood when the relevant clause is quoted, and noted by number. Alternate wording--additions, deletions, and changes—should be literally specified.
Like using the A300 itself, when objectives are clearly established, and specifications are accurately written, the work will go well. Cite references, such as publications, images, and documented practice, that support your position. *** Unsupported rants on unprovable philosophy are difficult for outsiders to understand, much less incorporate. ***
If the standard already cautions about durability, would you add flammability? or is flammability a type of durability? If so, your concern is already addressed. what is it you want to say?
