Another aerial friction rigging device?
All of the current devices are 'resistance amplifiers' for lack of a better term. They amplify whatever resistance is put on the rope before them. I would like to see an adjustable resistance incorporated in a brake so that the climber can decide how much it brakes by itself.
Here’s what I don’t like about the triple thimble and safe-bloc, not bashing them. They are both great tools and I use them a lot but I don’t like how the load can press the rope against the tree and increase the friction.
A very clever friend of mine suggested using a small torque converter in reverse.
An adjustment could be built in with a Bluetooth controller so that the rigger/cutter could make changes remotely.
Turn it completely open for trading the rope end back up. Then preset a load for the drop
Any Canadians here might know @Dave Spencer as the second place winner in ‘Canada’s Biggest Know it All’.
Just one question... When the rope is braked directly, it takes with it part of the heat. If you hold it in a wheel and brake the wheel, the brake has to absorb a larger part of the heat. Will that be an issue for the torque converter?
@Marsupilaami
I’m not sure how to answer your question.
If I recall the rope would pass around a tight Vee like you find as the self tailing mechanism on a yachting winch. Instead of a ratcheting mechanism the torque converter would control the rotation
All of this discussion was on the original Arbo discussion forum hosted by ISA No archives
In old mechanisms they used the non-linear air resistance to be progressive in regulating speed/power. Bit of a mind bender to imagine a fan/turbine braking a log drop. But, air is plentiful, free, cool supply to be had and just keeps taking a beating. On those DB Sala escape descenders they reach a progressive load/speed regulation by picking springs for the centrifugal brake shoes in the clutch assembly, but the drum and clutch shoes take a definite beat down and wear out, degrade their performance and need maintenance. And get hot. However, they behave a little like hydraulic resistance having speed dependence. Toughie is shock load proofing any mechanical powertrain sections.
Hardeehar, imagine the groundie having a helicopter collective stick to control the drop. Shouts "Flair!!!" "Good auto rotation on that one ..."
Jamie, been meaning to ask you what model mill you got? Do you have electronic speed control? I put a dc drive on mine and never looked back or budged a belt.
@Marsupilaami
I am picturing a ratchet block as used for sail sheets - they have textured or ridged, gripping sheaves - only instead of the sheave being locked one way, it is only breaked. Rope could be pressed into the sheave by a spring.
There could be a traditional, 'solid state' 'resistance amplifier' after it, which I imagine makes it easier to design.
Ideally the breaking force should be constant, for minimum anchor load.
So I don't see a centrifugal clutch helping.
Add in a battery winch for pre tension?
Maybe a traditional rack with larger bollards that are free to slide up or down the frame, with a spring at the bottom of the frame ends pushing the bollards together. The number of bollards engaged would be determined by the user and the weight of the load. Then when the load is taken by the rack, the spring would allow the bollards to spread out a bit acting like a shock absorber especially if the load is dropped onto the rack.
I bought a precision Matthews 25 with dro. It has electronic speed control with two position belt for high and low range speeds. For my needs this machine is perfect. My only complaint with it is the short quill travel (2”), but it has a dovetail z axis so that makes up for it somewhat. I bought the stand with it but had to lift the whole thing 8” to get the table to a comfortable working height. The whole thing cost less than $4000 and is small enough to fit in my little shop8C7B9197-36FD-4A9B-A148-55B901BCE912.jpeg
I looked up your machine. Nice. You're in the world of R8. Tip - keep a nice 6" adjustable for the drawbar and many other things. Make a small 3 or 4" 2x4 cutoff and use it as a hammer to pop the collet wedging when loosening, pound with the end grain. My machine takes one or two good taps to break free. One hand tapping, other holding the tool which may drop out of the collet as you tap. Likewise, one hand on tool, finger spin draw bar, then snug with adjustable while still holding. This will become 2nd nature.
Consider some type of hour meter for wear and tear.
It almost never hurts your tools to cut slower or lighter than for production, and prolongs tool life. No need for smoke except on stainless.
Also, old saw files that don't do well on chains are still great for regular metal work. Different standards of performance.
They don't sell my machine anymore. Its about 600 lbs with about 4" cylindrical vertical, similar table movements and sizes to yours. 4 T slots. manual feed, 0.001" dials. no dro. R8. 5" quill travel plus head vertical repositioning. Even with 5" I bought a short set of drill bits fractional sizes, saves my bacon every so often.
