I do tree work occasionally for friends and neighbors. It's always a one man show. One of the last removals I did was a 70 ft/14" pine leaning over a privacy fence into a backyard, towards the house, above shrubs. While it went fine, cutting up pieces small enough to throw to a clear zone or rappelling alongside larger pieces while lowering them from a figure 8 anchored just below the cut (so I could keep them off the shrubs as they got to the ground), taking the tops out seems hard when solo. I rigged the tops to the trunk thru a figure 8 with little slack, then leave some slack in the lower line after the 8 before securing the line so it can be released under load. This lets the tops run a bit before stopping, but still gives a fair jolt. I just don't have a 3rd hand to control the lower line while making the cut, as it's usually not one I want to one-hand. I then cut the top into pieces I can throw down while it's hanging alongside the trunk. Is there a better way? It seems like most techniques require a ground man. Had no place for a speedline and not sure that would be much better. I have lots of vertical caving and technical rescue equipment, but no spikes.
