RS is rapid super and has a squared cutting point (at the junction of the side cutting face and the top cutting face) as opposed to safer chains which round off that corner.
I "rocked" a chain into hidden metal and it combo bent those points in/down and scraped off the sharpness of the cutting edge. Conventional solution is to file or grind until those points reappear but that's a lot of tooth to lose in one go. I field fixed it till I had 95% of the upper edge back but got tired of filing. Rakers seemed ok didn't have dremel so left them. Chain cut again (from zero/powder!) but small chips, needed extra pressure.
Has anyone ever lowered the rakers to compensate slight rs chain tooth tip damage? I hate to lose that much tooth for an instantaneous metal encounter. About to recheck further filing w/out raker lower to see that partial solution. rakers seem to be on oem new 0.016" below tips height, still near that after my filing.
