Brando CalPankian
Carpal tunnel level member
- Pine City, MN
@Mallett My tractor has a grapple. It works great for logs and brush. It won't feed the chipper well.
In general, as stated, art and mini skids will out lift a small tractor. If you're not doing tons of massive removals the tractor does just fine. We've done big and removals with the tractor, you just cut pieces smaller. We often utilize 20 yard dumpsters for wood since the tractor won't lift high enough for a 30 yard.
I don't fully agree with the stability part. If the tractor isn't loaded, sure. But when carrying logs it can be plumb scary if you are on any sort of rough terrain. Often I pull bigger logs backwards super low to the ground so if it twists I don't die. Lol. There's times I feel like the frame will twist in half with 5' diameter oak or elm.
That said, low cost of ownership, dramatically more efficient than winching our hand pulling, and more approachable price points were why I got the tractor last year. This year we're getting an art.
