davidwyby
- PNW to SoCal
And a bunch of related jawjackin’
Now at 75 years old, I'm more of a fire wood cutter, than a faller or a climber !
They don’t hardly work as they are. Almost need split in halfDon't try to stack them. Too steep.
Great idea and visual for getting a lanyard to be flush and poundable in those small wedges. I'll add that touch on my next set of aerial wedges.The lanyard is old Slickline. A plastic shower curtain ring was used as the breakaway
Just bought one to try.That little blue Estwing is called the “Fireside Friend”. It’s useful to have on hand, but not the best wedge driver as the head is rounded and has no grip. It shines with stump cuts as it chops the dirty bark off easily and taps wedges for the final cut.
On at least one of those dead tops in Bremerton, I used a short wedges plus 1/4"-ish stacking plates. The face closed without breaking, so I pulled the wedge and plate and nibbled the side of one hinge with a handsaw. I think I chainsaw "tickled" the front of the hinge to thin it (that was backcut-first, btw).They don’t hardly work as they are. Almost need split in half
@Treezybreez - What do you mean "has no grip" ?That little blue Estwing is called the “Fireside Friend”. It’s useful to have on hand, but not the best wedge driver as the head is rounded and has no grip. It shines with stump cuts as it chops the dirty bark off easily and taps wedges for the final cut.
Would a gap face help with that?On at least one of those dead tops in Bremerton, I used a short wedges plus 1/4"-ish stacking plates. The face closed without breaking, so I pulled the wedge and plate and nibbled the side of one hinge with a handsaw. I think I chainsaw "tickled" the front of the hinge to thin it (that was backcut-first, btw).
I'm not positive if the face- cut closed or not.Would a gap face help with that?
