Textbook.More burnt firs on step ground in the CZU
Rico, what attributes to the long holding fibers on half the hinge and not on the other?More burnt firs on step ground in the CZU
Trying to learn here and want to compare with my own experience going forward…was a conifer so regular cells and compression cells. Were those longer fibers compression or regular?Sent it straight uphill as sidehill or downhill were not an option.
This tree had a pretty decent downhill and sidehill lean so I imagine the long fibers are a result of reaction wood.
isn‘t that quite normal? i thought that is because the front half of hinge fibers becomes compressed and the back part pulled apart.Rico, what attributes to the long holding fibers on half the hinge and not on the other?
I can see where the wedges were pounded in. With that particular stem, did you lay it uphill, downhill, sidehill?
Maybe to get up...while still tied in. And still better than the "stairs" just to the right.Homeowner: “I’ve got a ladder set up that you can use to get down the cliff”
Me: “hmm, I think I’ll tie in”View attachment 94010View attachment 94011
Yeah, I did use it once on rope, but didn’t love the idea of trusting a ladder someone else placed who knows how many years ago, especially starting from the top.Maybe to get up...while still tied in. And still better than the "stairs" just to the right.
My gaffs seem to find every rotten tree in my and surrounding counties.View attachment 94012
Should have taken more pics, but this was a butt puckerer. 60ft silver maple lead pointed directly at the house, deck, and service wires. About 20" at the girdled point with SIGNIFICANT decay for 5 or 6 feet above it. Had to do some light rigging from it to avoid the wires and fence. Thankfully my ground guy was extra smooth today.
Have a look at Rico’s photo and maybe you’ll see what I mean.isn‘t that quite normal? i thought that is because the front half of hinge fibers becomes compressed and the back part pulled apart.
Would this be the same as black willow?This willow oak destroyed this yard, but not the house thankfully. Cleanup today
View attachment 94023View attachment 94022
yes, i see what you are talking about. looks like the hinge is slightly fatter on the side where the whiskers stick out of the stump but there is also fibre-pull visible on the other side and they probably protrude out of the butt-log. maybe it has something to to where the fibres break under tension first, due to a slight weakness?Have a look at Rico’s photo and maybe you’ll see what I mean.
Short fibers along the “face cut” hinge edge and taller fibers along the “back cut” hinge edge is definitely normal. That’s not what I’m seeing in his photo.
While I see typical fibers across the entire hinge, I’m also seeing lots of taller fibers from the pith out to one edge much more so than the other. Perhaps the hinge is slightly wider toward the edge with the taller tension fibers?
Hi Rico, long time since chatting. Great pic. Was there a slight bias of lean to one side of the felling direction?More burnt firs on step ground in the CZU
Not a willow at all! Common name misnomer.Would this be the same as black willow?
Or, is that just a slang name I was taught? I've never heard it called willow oak before.
