I've contacted petzl land addressed the issue. Hopefully they'll change it.I hope this will put to rest the fears of carabiner choked anchors in specific/appropriate situations. This is not a recommendation for "remote" canopy anchors used for working the crown for example while pruning, we know a cinched carabiner is not a good solution for that use.
https://www.petzl.com/US/en/Profess...ngle-mode-with-CHICANE?ActivityName=Tree-care
Yea I'm sure they won't change that and I don't think they should.I've contacted petzl land addressed the issue. Hopefully they'll change it.
Petzl is very careful about the information they give us so I believe it is no mistake that they have that info up on their site...
Have u seen fiori's choked biner video?After reading the original linked Petzl document, one major issue strikes me. They do not refer to any specific type of carabiner for use in the choke configuration whereas they mention the zigzag and chicane directly. I'm no lawyer but I would think this opens up Petzl up to some liability in the fact that they are implying any carabiner can be used in this application. They didn't mention a specific carabiner because one does not exist for this application...yet. Though there are now quickie links on the market which solves the problem so just use that.
Do I think a carabiner will fail if used when choked to the spar...not the first couple times. Would I climb on a choked carabiner in an emergency, absolutely. Will I climb on a choked carabiner in every day climbing under controlled circumstances...nope. There are better designed and approved options.
Pic is an aluminum Petzl William ball lock that was used on a chipper winch...just for reference as what forces might do to the spine. This one has the old plastic gate, which also has cracks in it. I use this crab as my key chain carabiner now.
I forgot to add that petzl refers to choking the spar. So they endorse a choke on much bigger diameters than limbs like fiori did in his video and maybe like the limbs u winched into your chipper with that biner u showedHave u seen fiori's choked biner video?
Yep quickie and steel screw quick link are the best but I bet some where on petzls site they clarify what is best to choke with
A chipper winch is going to beat on the rope and biner or whatever is used no matter how it's configured... Especially if not using steel. A climber is going to be hard pressed to put the same forces on the biner.
... Why would I choose one that is safe in only a few configurations and circumstances?
Petzl has replaced the original content with this:I hope this will put to rest the fears of carabiner choked anchors in specific/appropriate situations. This is not a recommendation for "remote" canopy anchors used for working the crown for example while pruning, we know a cinched carabiner is not a good solution for that use.
With good reason or to maximize profit? I leave the reader to decide.
