southsoundtree
- Olympia, WA
Did you bent the handle, indicating overload?
I'm not real sure how I bent the handle. It was the last 6-8" or so of the handle and bent sideways a few degrees. Possibly an overload, or possibly someone being rougher with it on a job site than they should have (dropped something on it)Did you bent the handle, indicating overload?
I don't know for sure.I'm not real sure how I bent the handle. It was the last 6-8" or so of the handle and bent sideways a few degrees. Possibly an overload, or possibly someone being rougher with it on a job site than they should have (dropped something on it)
In my mind, an overloaded handle would try to bend backwards. Or twist due to bending sideways being easier then once off axis bending backwards creating a twist.
Sent from my SM-S908U1 using Tapatalk
Muggs what gives you the info that you had Masdam cranked up to 2k? If a lb measuring device, what rope was installed to allow that much force before slipping?This is what my bent handle looked like, after cranking it up to 2000 lbf. It's torqued and twisted, kind of hard to see. Not as obvious as I figured it would be. I don't use the crappy hook that comes with the puller, I replace it with a steel crab. After overloading mine, it wouldn't release the line, I had to cut it.
I really appreciate the offer but I already replaced the bent one. But thank you very muchWow...all you guys who take the time to video document things for us to be benefited by are phenomenal - thank you.
Time and effort, risk to your equipment, sometimes damage and costs - thanks.
(Almost positive I have a damaged Masdam with straight handle. Want the handle?)
I think I introduced even more confusion! You asked about the bent handle in post #21. I was thinking Muggs mentioned the bent Maasdam handle earlier, but that was @Brando CalPankian that said he broke a Maasdam in post #20.
