I used the snipe on this spar for 2 reasons. Since I had to high stump (shorten) this spar to clear a water line the snipe helped the butt to sit down. Secondly the spar was fat, but short, so the snipe help the spar get enough forward momentum and speed to power through the hinge. The snipe combined with a slightly gutted hinge mitigated the chances that it would come to a stop as the undercut closed up.I notice you are using some snipe cuts in addition to a conventional notch in a few of your photos @rico
Would you mind sharing some tricks and opinions about its use?
I swear you mark it with a laser level before you cut.Another 200 ft menace gone.
Right on, thanks for the explanation for that situation and the advice on its need to be square to the face.i is
The only advice I have on using snipes is to always remember that they can and will influence your lay, so you want to make sure they are squared up with your undercut.. I do this by simply using a log tape to measure out from the intersection of the undercut. Scribe a line and the snipe is perfectly squared up and will not have a negative influence on your lay.
Pretty much sure that there’s one of ‘em UFO’s…Kind of an odd one, looking down on a water tank as I was doing some work nearby.
I’ve got a few, that one is a Borntrager 53 ton. I really like it. Small, powerful,,What kinda jack do you have/ like?
Beautiful work at the stump Dan, and kudos to you for working in that burnt up wasteland for so long. You are a tougher man than me bro. I spent a few days last week back in the CZU area climbing and fallen some burnt firs on some crazy steep terrain and I couldn't get out of there fast enough.
Thanks Erik, yeah it’s pretty unpleasant sometimes but it feels good to do if you know what I mean. This portion is roadside hazards, cutting everything that will reach the roads, so we are making it safer for everyone and it actually looks a lot better after the machines go through and pull the logs and pile all the debris. Once they burn it and replant we can get a forest started again. Feels good to be a part of that.Beautiful work at the stump Dan, and kudos to you for working in that burnt up wasteland for so long. You are a tougher man than me bro. I spent a few days last week back in the CZU area climbing and fallen some burnt firs on some crazy steep terrain and I couldn't get out of there fast enough.
Not a day for tree spurs!I took a small hemlock top!View attachment 91146View attachment 91145
My foreman challenged me to go as high as I would to take the top on this little 35' Doug fir in between a house and fence, and I got to that diameter. I totally agree that new climbers should try to go to the highest they can go; small tops are easier to manage.Not a day for tree spurs!
That to held my entire weight on the lanyard.
Smallest top I've ever cut.
Newer climbers would benefit a lot by doing this. My finger is actually touching the trunk.
I'm tied into about another tree, above and left.
This is the regrown top (hemlock, so with a rot pocket) that is about 25' tall, slow growing in the shade of a lot of trees, winding it's way up into a cedar.View attachment 91157
