Philosophically i think to see fully, must look at both sides of coin, why and why not. Play scenario forward and backward in head as well. Soundest solution should look sound from all these angles, as perfect storm to key points, like a martial art. If for nothing else than to move most confidently, but then so much more.
Technique is a journey, really, never ending. Our context deepens through time.
very quotable/stolen, ty!
I love that question. And “where did you go to school to learn all of this?” “Well mam, I dropped out my freshman year and started working….
i have an arbo Tshirt that says am using high school diploma to fix what your college degree messed up.
Have had engineers stop me ranting to boss, that i couldn't do what i posing to; but was my butt on the line literally... Afterwards they are all pissy, slamming stuff and leaving usually seems.
Daniel's mini-notch is what i call a face within a face, inner face closing earliest and thus ruling.
These few points below i think can give fuller , open door view of the works, rather than the usual peek under the closed door.
i think BC is from massive force bound against self w/o relief path that exceeds the capacity of the wood. In my imagery over ruling the constitution of the spar as a container of that force. Noting, that can play the same cuts, angles etc. all the same as dropcut/snapcut , hop a top etc. quite successfully with everything set to same 'volume control'/dial except the mass volume control turned way up in felling then higher leverage multiplier than climbing etc. for sum total leveraged force clear off the scale; for sum total. i also imagine a backcut going so slow(in ratio to relief needed) the massive raging urge of force can't flow forwards and almost seems like then can rush/divert upwards between the 'sheets'/layers urging separation/ungluing. The separation seems to go between the more leathery outer 'skin' and inner 'bone' of the tree wood. Then kinda too hammering if 'stutters' at real slow, mebbe some actual mini stop and restarts to aggravate away from smooth , clean, flowing, committed fall.
Most things fail from overwhelming sine/cross forces; not aligned force overwhelm-ment of cosine . Wood is about 70% tension strength of compression as thumbrule. Tension and across shear failing then, seen as expected.
Total energy trying to flow cleanly home will be e=mcSQUARED. The squared part is the velocity that is very slow/ not built up to usual squared/compounding volume yet in early closes. Note how formula has just 2 parts: static leveraged mass, and then when that nominal is overcome we are squaring then speed as a compounding, exponential multiplier. The dynamic state, once achieved, rules here and exponentially as that increases in value further from nominal static. This dynamic state can carry tree home with inertia guiding it as the exponential compounding , most determining force, once engaged enough.
i think we can see the strongest of these also in the 2 extremes of too much downward force (cosine) in shallow lean X slowness
>>slowness extreme in early full face across close like accidental kerf horizontal across buried in the face as the slated is bypassed.)
Or in the opposite extreme of too much forward lean (sine)tension on fibers, too slow a relief for the building leveraged forces X again slowness. But as all positions between extremes have some of each volatile, and still have to stir in speed to inertia, wood type and condition, can conjure BC several ways to same equivalent sum failure.
Other dispositions of CoG (length x lean )are between these antagonistic extremes have some of each , of the 'parental' extreme effects. Scenarios between these extremes are antagonistic as they raise effect of 1extreme at expense of the other (too little lean/massive cosine vs. too much lean/massive sine). But anyway can dialup BC from several combinations to same overwhelming sum total on the scale. Then there is how species and condition slant the benchmark expectations this way or that. But always forward momentum as flow of force and relief of raging forward force (else more likely to then surge up fiber columns then i think ) forsaken in full across early close I think might be most consistent way of conjuring the beast, amidst the rest of the formula to overwhelming the wood capacity.
